Can't create a JIRA Classic Templates anymore
marion baillat February 27, 2020
Hi there,
I want to create a new project. I can select the Next Gen template only (Scrum/Kanban) but I can't create ANY Classic template (Scrum/Kanban) - It is just no longer coming through.
We thought it was our license, but it is not.
Can you please investigate ASAP.
Many thanks,
Marion
Jack Brickey
Is it possible that your admin has disabled creation of projects other than NG?
Hi Jack,
I'm a site admin on JIRA. I have all site access.
I can create as many projects as required.
I can create next generations templates only -
I receive this error message when I am trying to create a classic template (Scrum and/or Kanban)
See screenshots attached below.
It seems some people had encountered similar issues in the past, and has to do with a JIRA bug and the JIRA team may have to fix our database? Can you please let me know?
Marion
Jack Brickey
I would suggest reaching out to Atlassian Support to verify that claim.
marion baillat February 28, 2020
Yes, I would love to have someone from JIRA Tech support to get back to me ! :)
Jack Brickey
Did you try to connect with them here Support
marion baillat March 1, 2020
Yes, thanks Jack. The ticket is now closed and the matter has been solved, thank you!
Jack Brickey
@marion baillat, can you share here what the issue was?
