Can't find prometheus exporter for jira
akinadeyemo1
Hi, I wanted to install plugin for prometheus exporter for Jira and Confluence but realised that I could not find it in "Manage Apps".
Could you please assist, I need to have it installed to monitor the metrics our Jira and confluence applications.
We run Jira 8.5.1 and Confluence 7.3.3
Alexey Matveev
April 21, 2020
akinadeyemo1
Thanks for your response but I meant I could not find it within the applications because I want to have it installed. Would you know how to install it when downloaded. I have got no instruction about this.
Thanks for helping out.
Alexey Matveev
April 21, 2020
Download the jar files for Prometheus for Jira and Prometheus for Confluence.
Then for Jira
1. Go to cog wheel -> Manage apps:
Screenshot 2020-04-21 at 19.29.30.png 2. Make sure that Manage apps is chosen in the vertical menu:
Screenshot 2020-04-21 at 19.30.27.png 3. Push the upload app button:
Screenshot 2020-04-21 at 19.31.01.png 4. Choose the jar for Prometheus for Jira and push the upload button
For Confluence read this instruction:
2. Make sure that the Manage apps vertical menu is chosen and use the upload app button to upload the Prometheus for Confluence jar file:
Like • akinadeyemo1 likes this
akinadeyemo1
Thanks very much for your quick response. I have been able to successfully load the plugins into Jira and Confluence.
I will go ahead with further configurations and let you know how it goes, hopefully things will work out fine.
Thanks a million!!!.
Akin
akinadeyemo1
Hi Alexey,
Please I have got one more issue, I have configured my prometheus.yml file but my prometheus service would not start. I have gone to the prometheus exporter GUI to find out the location of the metrics by clicking on Prometheus exporter for
jira->configure->exposed metrics are here->and then have the location of the metrics.
My configuration below
- job_name: 'jira'
scheme: https # change to http if don't you have https
metrics_path: 'https://jira.domain.server.bitcom/plugins/servlet/prometheus/metrics'
 static_configs:
 - targets: ['IP_Address:8081'] # Jira host and port you serve
I restarted prometheus service but service never started.
'Usually the jira url is always accessed through
https://jira.domain.server.bitcom not through the IP_address:8081
as indicated above.
Before adding the job name above I was able to start prometheus without any issue but including the details to scrape jira metrics would not allow the service to start.
Can you advise please of proper configuration.
Thanks for your help.
AA
Alexey Matveev
April 22, 2020 edited
Hello @akinadeyemo1 ,
It would be better, if you created a separate question for your new question, in this case users with the same question would find the answer easier.
Answering your question:
metric_path should be like this:
metrics_path: '/plugins/servlet/prometheus/metrics'
You do not have to include the host and the port information in the metrics_path.
The target parameter you can provide 'IP_Address:8081' or just 'jira.domain.server.bitcom'
Like • Deenesh Sampath likes this
akinadeyemo1
Thanks a lot, that answers my question. I will take to your advice next time to create a new topic. I had to do this just to call your prompt attention. Thanks for always helping.
I have done the solution you suggested but prometheus service still not starting. I am thinking I have to install nginx to enable me to use https to access the web page behind proxy instead of http which I have been using before.
Alexey Matveev
April 22, 2020
You need to go to Prometheus -> Targets and have a look what the problem is. If your prometheus do not start then have a look at the error, why it is not started
akinadeyemo1
Thanks will do
