Hi!
I'm looking to edit a simple form but the dotted icon saying 'drag to reorder' isn't working. I'm on MacOS and have already tried Chrome and Safari.
Hello @Jonathan Castrillon
What type of project are you using? Get that information from the Type column on the View All Projects page under the Projects menu.
Can you provide a screen image of what you are seeing?
Hi, thanks for the reply. Here's a screenshot. Type seems to be Company-managed business. I can't reorder the form items.
I am having the same experience in my Free subscription. I did not find anything related to this in Atlassian's public backlog.
https://jira.atlassian.com/secure/MyJiraHome.jspa
I recommend that you report the problem directly to Atlassian in a support ticket.
https://support.atlassian.com/contact/#/
You will need to be a Jira Administrator to submit a case.
If you do submit a case, it would be great if you report back here what you learn.
The tooltip says 'drag to reorder' but the options actually appear when double-clicking the icon.
Excellent!
I got them by single-clicking.
I'm also experiencing the same problem in company managed software
I just tried double-clicking the reorder icon and the options appeared. It's the tooltip that's confusing us.
Hi Jonathan - Welcome to the Atlassian Community!
We will definitely need some screen shots. And when you say it is not working, what EXACTLY is happening?
