Can't reorder issues in the backlog view
eren
I can't simply drag issues up or down in JIRA next gen backlog view.
I've checked that it works fine in mobile app. This was working fine and stopped working recently.
I've turned on all features, using latest. Safari browser on Mac. Tested on other browsers and issue is persistent.
Any idea what's happening? Thank you
Anton Romanov
March 20, 2020
Same problem. Also can't drag issues to a sprint.
Scott Fraser
March 20, 2020
I am experiencing the same issue with next gen project backlogs. I am able to reorder backlog issues in classic projects.
Scott Fraser
March 23, 2020
A bug was logged as the result of a different version of this same question. Looks like a fix has already been pushed. It is working for me now.
https://community.atlassian.com/t5/Jira-Software-questions/Reordering-issues/qaq-p/1329197
Kamrul September 22, 2022
Did you check the Ranking. It should be enabled in the filter.
Dan Chisholm April 21, 2021
not fixed, definitely broken, really unfortunate.
today's date: 4/21/2021
Safari Version 14.0.3 (14610.4.3.1.7)
Parth Gulati
March 22, 2020
Same here - can't do the thing in the backlog that the backlog is literally designed for.
Can't even drag any issues into a Sprint
