Can't there be multiple recipients for a subscription of a filter anymore? :(
Severin Wanzenried January 28, 2016
This question is in reference to Atlassian Documentation: Working with search results
In earlier versions of JIRA there was the possibility to add multiple recipients for a subscription of a filter what was really handy. Isn't this possible anymore in the latest JIRA software?
Jobin Kuruvilla [Adaptavist]
February 2, 2016
Do you have the " Manage Group Filter Subscriptions " global permission?
Severin Wanzenried February 2, 2016
Thanks, this was the link I've needed. smile
January 30, 2016
Yes, you can. You will need to be a member of the groups before you can subscribe to them.
Severin Wanzenried January 31, 2016
Thanks for your answer. Unfortunately I can't find the field where to configure that. The subscription in the background of the screenshot is from an earlier version of JIRA (5.xx), but now in JIRA software 7.xx I don't find the way neither to create a new subscription that applies to a group of users nor to edit the subscribed field of existing subscriptions. Could you give me a hand, please?
p.s.: I am member of the subscribed group
February 1, 2016
Is the filter shared with the group? Or is it visible only to you now?
Severin Wanzenried February 1, 2016
It is shared with anyone. But according to me the subscription screen doesn't change if I take a published or a private (visible to me only) filter.
Read the story
