Can't update jira issue with REST API
red888
I'm trying to do this with powershell, but I'm getting 400 errors:
$RESTURL = 'https://mycomp.atlassian.net/rest/api/latest/issue/PROJ-61'
$body = '{"fields":{"assignee":{"name":"me"}}}'
$restcreds = [System.Convert]::ToBase64String(
[System.Text.Encoding]::ASCII.GetBytes(('me' + ":" + 'mypass123'))
$httpheader = @{Authorization = "Basic $restcreds"}
$restParameters = @{
Uri = $RESTURL;
ContentType = "application/json";
Method = "PUT";
Headers = $httpheader;
Body = $body;
Invoke-RestMethod @restParameters
If I remove "body" from the request and change it to a get I get back data successfully. It seems I just get modify the ticket
Tarun Sapra
August 9, 2016
Here is your answer - https://answers.atlassian.com/questions/156863
Make sure you have assignee field on the edit screen of the issue.
Tarun Sapra
August 10, 2016
has you issue been resolved?
Tarun Sapra
August 9, 2016
Tarun Sapra
August 9, 2016
From the docs - "The simple way to update an issue is to do a GET, update the values inside "fields", and then PUT back."
Thus do a get request and then then a put request with the same json data and just modify the "assignee" filed to a proper user ID , "me" isn't a userId it seems which you are doing right now.
