Can't use Jira components after deleting Compass
Jason Haynes May 5, 2024
Signed up for Compass, because it said I could always switch back.
Switched back to Jira.
1) All of my existing components were erased!
2) I cannot create any components in that project!  (I can in other projects.)
Any ideas?  Also, beware of "You can always switch back!" I guess.
Tankem Williams
I took some time to test your issue, but I'm glad you found the switch LOL
Tankem Williams
May 5, 2024 edited
Hello Jason, Thank you for your question. If I got your issue correctly, All your existing components were erased after switching from Compass back to Jira components.  I did create a test case below and did not see any issues. Please read through the steps and let me know if yours is different. Please share screen captures when possible to elaborate.
Created two test components
Go to Compass and create one component
Switching back to Jira you noticed both Components created in Jira are gone and now replaced by that from Compas
This is because the switch is ON
Once you turn the Switch OFF, you should get all your Jira Components back
Let me know if this helps.
I found the setting, and it brought back all of my old jira components!!
First of all, if anyone's having trouble removing Compass, that instruction is here: https://community.atlassian.com/t5/Compass-questions/Remove-Compass-from-cloud-site/qaq-p/2014427 (and I notice someone else posted the same question I had).
Somehow I found the switch: 1) Project Settings 2) Components 3) In the upper-right corner, it'll say something like "Compass components" (even though compass is uninstalled).  Click it, then select Jira components.
Carlos Garcia Navarro
May 5, 2024
Thank you for posting your findings!
FREE
atlassian, loom, AI, meeting recording, community
[NEW] Record your meetings with Loom
Welcome to great meetings, with less work. Automatically record, summarize, and share instant recaps of your meetings with Loom AI.
Learn more
