Looking for a report that will show these fields:
Key | Summary | Comments
How do I retrieve data from the Comments field in a report?
to the best of my knowledge, comments can't currently be added as a column to Jira's issue views and reports.
The only built-in solution that I can think of is to use Jira Automation to copy the issue's comments (or parts of it) into a custom field (probably of type paragraph/multi-line text), and add this custom field to your issue view. You can create a rule that is triggered by a new comment action, and then use a expression like e.g. {issue.comments.last.body} to access the latest comment.
Alternatively, if you're open to solutions from the Atlassian Marketplace, there's more options available. I'll add more information below.
Hope this helps,
Best,
Hannes
... and just to expand on the last point: If you're open to solutions from the Atlassian Marketplace, and/or don't want this to eat into your automation budget, you may want to have a look at the app that my team and I are working on, JXL for Jira.
JXL is a full-fledged spreadsheet/table view for your issues that allows viewing, inline-editing, sorting, and filtering by all your issue fields, much like you’d do in e.g. Excel or Google Sheets. It also comes with a long list of so-called smart columns that aren’t natively available, including the content, date, or author of the last or first comment, all comments, etc. etc.
This is how it looks in action:
As you can see above, you can easily sort and filter by your smart columns; you can also use them across JXL's advanced features, such as support for (configurable) issue hierarchies, issue grouping by any issue field(s), sum-ups, or conditional formatting.
Of course, you can also export your data to Excel/Google Sheets or CSV in just one click.
This all just works - there's no scripting or automation whatsoever required.
Any questions just let me know!
Show up and give back by attending an Atlassian Community Event: we’ll donate $10 for every event attendee in March!
Join an Atlassian Community Event!
