In Kanban Board,
I want to implement like below:
1) Creating New Screens like Screen 1, Screen 2, Screen 3 other than Create, View/Edit Screen.
2) Associating those 3 Screens to one issue type.
3) Available Status are Open, In Progress, Pending, Closed.
4) After creating issues,
When status is Open - we have to show View/Edit Screen.
When status is In Progress- we have to show Screen 1.
When status is Pending- we have to show Screen 2.
When status is Closed- we have to show Screen 3.
So Based on status, screens have to display.
Please help me out.
Thanks in Advance.
To be clear, Create/View/Edit are the “types” of screens. What else can you do to and issue? What you can do, and likely are asking for, is to create uniques screens and use them for one of the three type functions. This is what @Vishwas has conveyed.
You can do that easily using Screens and Screen schemes. Just create all the screens with the fields you want and add them to the screen scheme of your project. Then you have to go to the particular workflow and edit it and associate the respective screens to the transitions. May be you can start here from referring to this document https://confluence.atlassian.com/jirakb/mapping-a-screen-to-a-workflow-transition-720634253.html
