Can we create Gadget using Jira Script Runner ?
Sanjay Dhandare
I have created different scripted fields in my project for report configuration and now I want to showcase scripted field in gadget using script runner for jira. Is it possible ?
Note :
I am using Jira Script Runner for developing various report
Thanks in advance !
Alex Koxaras -Relational-
Hi @Sanjay_Dhandare
I'm not sure that scriptrunner can work like you want it to work. In order to make a gadget an add it on your instance, I would expect to use javascript and HTML/CSS to build one, and then deploy it on your instance.
