Can we freez reporters view access in Jira after 2nd transition
Tushar.Kamble
Want to restrict report view access in Jira after issue got assigned to internal Dev team.
Is it possible?
Roman Kersky
August 1, 2019
Hi. You can do this using the Security level (https://confluence.atlassian.com/adminjiracloud/configuring-issue-level-security-776636711.html)
You can add a security level selection to the transition screen.
Tushar.Kamble
Thanks Roman, Let me try with your solution.
John Funk
August 1, 2019
Hi Tushar - I don't think that is going to be possible in a global way. Permissions are granted at the project level and can be associated with issue types. But you might be able to do it with some type of combination of boards where the board filter controls that somewhat.
