Can we have dummy statuses ?
unnikrishnan
Hi All,
When we create a customized statuses , jira system asked to keep under either Todo, in progress or Done statuses. I have a situation where I wanted two done stages in my workflow , one is dev done  and next one is release done.  I need the burn down and all other sprint tracking only till dev done , however I need the release done status for the overall flow.  If I include only first done on my board , I am not able to do the complete and close the  sprint. if I include both done status on my board , my burndown chart is  not useful at the time of sprint as it will not go down until both done have completed. and all my report are going bad.In order to address this issue, I would like have a status as dummy which done not have any impact on the sprint flow.
Do we have any option to have a dummy status , which cannot be tagged to todo , in-progress or Done ?
Daniel Ebers
March 16, 2020
'To Do', 'In Progress' and 'Done' are status categories. The specific statuses are mapped to one of them.
There was a suggestion to add more categories to statuses which has been closed. https://jira.atlassian.com/browse/JRASERVER-36241 Atlassian won't implement new status categories.
There might be some Apps in Market Place which could probably come close to the requirement.
By reading your use case I am not 100% sure if another status categorie would fix the problems you are trying to resolve. In the last sentences you wrote about statuses which you want to create. This, of course, can be done.
(https://confluence.atlassian.com/adminjiracloud/configuring-statuses-resolutions-and-priorities-776636333.html)
Daniel
