@chirag There are a lot of people who run the application on GCP. It however is not listed on Atlassian's supported platforms page https://confluence.atlassian.com/adminjiraserver/supported-platforms-938846830.html
My guess is that Atlassian would still support it but would run into limitations with that support. For instance if there was an issue with the configuration of the environment they would not be able to support that. So the answer of support would be yes but could be really limited.
I would suggest looking at AWS or Azure since they are fully supported.
