×I have a scenario where several hundred field values need to be disabled for a multi-select list custom field in Jira. Is there any way to bulk disable custom field values within the Jira interface, perhaps with Scriptrunner?
Or, is disabling values one by one the only way to handle this from within Jira?
Andrew
I was able to use this to disable options from a customfield. I can't remember what kind of customfield it was but it may lead you to the right place. This script was used in the Script Console
import
com.atlassian.jira.component.ComponentAccessor
//Any ticket number can be used that has the targeted custom field
def
issue = ComponentAccessor.getIssueManager().getIssueObject(
"JA-iiii"
def
customField = ComponentAccessor.getCustomFieldManager().getCustomFieldObjectByName(
"Custom-field Name"
def
optionsManager = ComponentAccessor.getOptionsManager()
def
options = optionsManager.getOptions(customField.getRelevantConfig(issue))
options.
each
if
(options)
optionsManager.disableOption(it)
Oops!!
Unfortunately, your script was updating all options in the given custom field 'we used custom field by name' rather than updating custom field + single jira ticket.
it updated 3K+ records in a go quickly.. the script needs to be developed before we execute everything.
@Mohan Sundar Have you made any improvements to the script before we execute,, because it messed up our data?
Srikanth Ganipisetty
@Srikanth Ganipisetty The script is to disable all the custom field values if they are enabled.
I had changed the issue id and the Custom field name and then executed it.
Thumb rule: Try to have a test custom field with few values and test project to test any such scripts.
I think this is a valuable lesson to test scripts in test environments before just executing random internet code.
I agree @Raynard Rhodes I ran on test environments, but we have 1000_ records to turn back into enabled, where my intial task is to disable only 50+ records. It's a valuable lesson.
@Mohan Sundar I should have do that trying it on a test custom field.
Hi ,
I have a custom field[Single Select list] with 5 options in it. I have disabled one option with Custom Field Configuration in Jira. When i import issues with CSV with disabled Custom Field Option it is creating new issue..how to block it from creating issues with disabled options.
Suggest me some answers,
Thanks in Advance
Can you explain your use case a bit in detail?
Using ScriptRunner you can create a behaviour to disable those values or split the custom field contexts and few more things as well with a custom script.
Ravi
Sure thing. Essentially the custom field is a multi-select list of our customers over the years. We formatted it this way so that users would not make errors in spelling or use inappropriate shorthand/abbreviations when referring to customers. With a select list, we can ensure the customer names on tickets are always spelled the same way, we can use the values in logic, and VLOOKUPs with data manipulation from reports from other systems, etc.
Because this field is available in many of our Jira projects and because it's considered the standard authoritative source for customer names in Jira, it only has one, global field context.
Over the years it's become extremely bloated as lapsed customers or accounts that are no longer active are still selectable. We still need their values in Jira to query and report on, but they will not be newly selected, so I'd like to disable them to clean up the current selectable list for end users.
I have a CSV of exactly the custom field value options that need to be disabled, exactly as they are spelled in Jira. Since it's several hundred values, I'd love to be able to import that list and have Jira disable any value that matches for my specified custom field, rather than doing so one by one in the Custom Field>Edit Options page.
But, that's where I'm stuck. I'm not sure such a thing is possible within the Jira UI.
Hi Andrew, I have a similar scenario. Were you able to figure it out?
Hey @Jaswanth P !
I wasn't able to find a solution that utilized my CSV list. But, @Merita Bushi, another admin on our team, discovered that you don't have to wait for the enable/disable/edit request to resolve in your main "edit options for custom field" screen if you open in a new tab.
So, I'm able to get through these pretty quickly by simply command+clicking (I'm on a Mac) on the "Disable" option as I scroll down the custom field value options.
I can't completely vouch for safety of this method regarding system performance, although I haven't had problems. You may want to monitor your CPU or perform this task outside of prime business hours just in case. I was just tired of waiting for the value option list to refresh after every single edit or disable action. Since the total list is so long, it would take 15s to refresh after making an option edit, disable, or enable and when you have to edit or disable 100 options, that really adds up.
Hopefully this helps a little,
Andrew
Thanks Andrew. Not a bad approach if we can spend few minutes. I will try it. I have about 500 values to disable and was planning to write a SQL script to set the 'disabled' flag to 'Y' in customfieldoption table.
It would be great if scriptrunner or Atlassian themselves provide some solution to this.
Right, yeah with 500 it'll take a bit done manually. Sounds like you're going to work through this method and have already seen this page, but linking it here just in case!
I scanned through some developer docs but couldn't figure out how to do what I was searching for. I came upon a few potentially related tickets, but one is already resolved as won't do.
https://jira.atlassian.com/browse/JRASERVER-41661
https://jira.atlassian.com/browse/JRASERVER-60274
There could very well be a useful fragment in the Scriptrunner Library. I just couldn't find it and decided to start going through the list manually.
If you go with the SQL script route, I'd be interested in hearing how it turns out and if the process was relatively straightforward or not.
Take care,
Andrew
which method works for you both? we have 100+ in a MLCS field consisting 6000 records, and the page is really slow and it takes so long to update 1 field and to wait for the refresh etc.
Jaswanth, have it worked through SQL method?
