Can you create a report for components?
Blaine Vriezelaar November 27, 2017
I'm trying to create a report in Jira Service Desk using components but i'm not sure what the JQL expression would be or if it's even possible.
I want to report on how many issues we have based on components and export it into a csv.
Tarun Sapra
November 29, 2017
Have you looked into 2 dimensional gadget provided by JIRA
https://confluence.atlassian.com/jira064/adding-the-two-dimensional-filter-statistics-gadget-720416991.html
You can map component vs issueTypes  in above gadget.
Jack Brickey
November 29, 2017
Blaine, if you are simply wanting a table showing the number of issues by component and you plan to put eyes on it regularly then Taurn's recommendation is perfect IMO. Create a dashboard and add the 2D gadget. I would use component for Y-axis and Status for the X-axis. It would look like below with a total off to the right.
Like • 5 people like this
Boris Berenberg - Atlas Authority
November 27, 2017
Can you describe what you hope to get? You could do something like:
PROJECT = ABC ORDER BY COMPONENT and then export to Excel CSV within the the Issue Navigator
Certainly. When I go into the Project Settings\Components, it gives me a list of all the components I have and how many issues are associated with that component. I'd like to export that to a csv or create a report in the Reports section using that information.
I'm not sure what'd i'd put in for the JQL Filter.
November 27, 2017
I would just select the contents of the page components page and paste it into excel or google sheets. It will likely format correctly and give you what you need. I don't think the report you're looking for will be created by Jira because all reports in Jira will count issues. I guess you could technically have an individual series for every component if you need it over time?
Blaine Vriezelaar November 28, 2017
Thanks, Boris. I think copying and pasting will be the easiest route. No, we won't need an individual series for each component.
Appreciate it!
Thomas Burke
June 9, 2022 edited
nevermind....
there is no delete for comments btw.  ;-)
found this though
https://community.atlassian.com/t5/Jira-questions/Common-Components-Report-in-Jira-Service-Desk/qaq-p/1545429
Daniel DuBravec
I am not sure if Service Desk is different, but in JIRA, I selected the components selection on the left nav to view the entire list  (there were 100!)  Highlighted the text, which included the component name and the component lead in the browser (chrome) and then pasted in excel.  It worked surprisingly well.
Alexey Matveev
November 29, 2017
There is no such JQL.
You can use gadgets. For example Issue statistics gadget
https://confluence.atlassian.com/jira064/adding-the-issue-statistics-gadget-720417074.html
But you can not export it to Excel
