Can you create sub-queues?
Joshua Munoz
This question is in reference to Atlassian Documentation: Making queues for your service desk teams
It looks like it's not possible, but is can I make sub-queues inside other queues?
4 votes
Gerry Tan
September 19, 2016
No but you can use combination of JQL and queue naming & ordering to give the impression they are sub-queues. For example:
image2016-9-20 13:12:53.png
gbh2930
What are the instructions for how to achieve that sub-queue indentation effect?
Eleanor Hart
I have this question too!
Eleanor Hart
Figured it out! It's literally just copy and paste the arrow symbol ↳ or apparently you can use unicode for the arrow symbol (U+2183). I hope this helps someone :D
Like # people like this
Cengiz Akyildiz July 23, 2018
The arrow symbol ↳ make sense also using this free add-on, I wonder if previous reply points out that
https://marketplace.atlassian.com/apps/1214767/queue-collapse-for-jira-service-desk?hosting=server&tab=overview
I like the way it helps you to organize your queues visually and have nested collapsible queues. The only thing you should not forget, you need to set your filter for each queue individually (does not inherit any jql filter from the parent queue).
Laura Ainsworth (UK) September 16, 2019
I have downloaded the add on that you have suggested but I am unable to get it to work. There is a link to the documentation, which I believe would help, but the link is broken and takes me to a page not found error message. Do you happen to know how I set this up?
Fabian A. Lopez (Community Leader - Argentina, Florida, California)
that app is free and sometimes it is not supported. I have the same issue.
I found another app that could help managing the queue but it is not free.
https://marketplace.atlassian.com/apps/1216386/queues-for-jira-service-desk?hosting=server&tab=overview
Like Capi [resolution] likes this
dilipabegune April 25, 2022
Such a minor function. cmon Atlassian ...
