Can you set up access control for Screen tabs?
Ricky M March 29, 2019
Is it possible to restrict access to certain tabs within a Screen?
Say I have a tab in my screen called "Internal Data". How can I restrict normal JIRA users from seeing that tab, but grant them the ability to see other tabs?
Fabio Racobaldo _Herzum_
Hi @Ricky M ,
using built-in feature you can't do that. I had the same issue and I fixed using https://marketplace.atlassian.com/apps/23216/field-security-plugin-for-jira?hosting=server&tab=overview .
Using this plugin you can hide specific fields to specific users, moreover the related tab will be hide.
Hope this helps,
Fabio
