Canned Response Administration
Gor Greyan
August 18, 2025
Hi, Dear Community!
We have "Canned Response" in the comment section in Jira. Now, for one of my employees, the section has disappeared. I couldn't find the plugin or anything else; where does it come from?
Could someone hint, is it a plugin or something else?
2 accepted
Matteo Vecchiato
August 18, 2025
Hi @Gor Greyan ,
The canned responses is natively available in the Data Center versions.
The feature is available only for agents, I guess it is probably related to permissions or agent license; have you checked if those users have the agent roles and permission to edit the issue/work item?
Regards
Gor Greyan
August 18, 2025
Hi @Matteo Vecchiato
Thanks for the answer.
Utkarsh Agarwal
Hi @Gor Greyan
Welcome to the community!
The "Canned Response" feature in Jira Service Management (JSM) is only available to users with an agent license. If a user can’t see this option, it’s likely they don’t have a JSM agent license or the correct permissions. Double-check that the affected user is assigned to the JSM agent group (like jira-servicedesk-users). This feature isn’t available for Jira Software/Core only users or portal customers.
Hope this helps!
Kind Regards
Utkarsh
Gor Greyan
August 18, 2025
Hi, @Utkarsh Agarwal
Yes, thanks a lot for helping. The issue was with the agent's permission.
