Cannot add mentioned in MS Teams
bee.eo February 13, 2025
I have enabled Jira cloud app in our project in MS Teams, I was able to see my filtered list, able to add comment, to a JIRA issue, add description however I am not able to use add mentioned in the comment. In fact the add mentioned name on existing comment field does not show up when I view it from Teams however it is working perfectly fine if I go into JIRA directly.
Hi, Lucy, please update the task, in JIRA. In Teams it becomes,
Hi,   please update the task
Can anyone shed some lights how to fix this? Thanks.
Jack Brickey
Hi @bee.eo , indeed this is a current limitation. I believe that GDPR is involved here. At the risk of potentially stating the obvious, the userid in Jira is not mapped to the userid in Teams which prevents being able to directly mention users between the two apps. Disclaimer - my focus is mostly in Slack but I believe the issues are the same.
bee.eo February 16, 2025
Thank you!
Register today
