Cannot create a fragment with a corresponding REST endpoint
Mouna Hammoudi
August 12, 2022
I am trying to create a custom web item that navigates to a link when clicking on it. Here is a screenshot of the way in which I have created the custom web item:
I have also defined a REST endpoint as you can see in the following screenshot
Here is the corresponding code for my REST Endpoint that I have written in the script editor. The problem is that nothing works, even the string that I am writing to the log "THIS IS MOUNA'S TEST" is not displayed in the log. So when I click on the menu item "Mouna Bulk Summary", I get redirected to this error page. How can I fix this and make my fragment/REST endpoint work?
import groovy.transform.BaseScript
import com.onresolve.scriptrunner.runner.rest.common.CustomEndpointDelegate
import javax.ws.rs.core.MultivaluedMap
import com.onresolve.scriptrunner.runner.ScriptRunnerImpl
import com.atlassian.sal.api.ApplicationProperties
import com.atlassian.sal.api.UrlMode
import javax.ws.rs.core.Response
import org.apache.log4j.Logger
@BaseScript CustomEndpointDelegate delegate
callFeaturePerformanceImpactAnalysis(httpMethod: "GET") { MultivaluedMap queryParams ->
    def log = Logger.getLogger("atlassian-jira.log")
    log.warn("THIS IS MOUNA'S TEST")
    def user = ComponentAccessor.jiraAuthenticationContext?.loggedInUser
    def issue = ComponentAccessor.getIssueManager().getIssueObject(queryParams.getFirst("issueId") as Long)
    def baseUrl = ScriptRunnerImpl.getOsgiService(ApplicationProperties).getBaseUrl(UrlMode.ABSOLUTE)
    def redirectUrl = "https://secapps.eur.ad.sag:9888/FPIA/?iTrac=${issue.key}&reporter=${user.key}&baseURL=${baseUrl}"
    Response.temporaryRedirect(URI.create(redirectUrl)).build()
August 17, 2022
Hi @Mouna Hammoudi
The approach that you are taking will not work.
If you observe your REST Endpoint code, you named the method callFeaturePerformanceImpactAnalysis, i.e.:-
However, when you try to invoke the REST Endpoint, the URL you are using is:-
http://itrac-dev.eur.ad.sag/rest/scriptrunner/latest/custom/MounaBulkSummary?issueId=1281074
Which will not work. In your REST Endpoint configuration, there is no such method called MounaBulkSummary.
You should instead invoke the callFeaturePerformanceImpactAnalysis method, and the URL your should use is something like:-
http://itrac-dev.eur.ad.sag/rest/scriptrunner/latest/custom/callFeaturePerformanceImpactAnalysis?issueId=1281074
I hope this helps to answer your question. :)
Thank you and Kind regards,
Ram
Register Now
