I am trying to upgrade jira software from version 8.20.6 to 8.20.10 – data center using docker compose.
I have always upgraded by taking down the docker container, updating the version number in the docker-compose file and run the docker container again.
Here is the error that I get:
Cannot find /opt/atlassian/iira/bin/setclasspath.sh
Maybe I need to delete the container before restarting it? I am always a bit careful with docker as I don't want to lose or delete everything.
Upgrading the docker engine solved the problem:
https://docs.docker.com/engine/install/ubuntu/#install-using-the-repository
sudo apt-get update
$ sudo apt-get install \
ca-certificates \
curl \
gnupg \
lsb-release
Add Docker’s official GPG key:
$ sudo mkdir -p /etc/apt/keyrings
$ curl -fsSL https://download.docker.com/linux/ubuntu/gpg | sudo gpg --dearmor -o /etc/apt/keyrings/docker.gpg
Use the following command to set up the repository:
$ echo \
"deb [arch=$(dpkg --print-architecture) signed-by=/etc/apt/keyrings/docker.gpg] https://download.docker.com/linux/ubuntu \
$(lsb_release -cs) stable" | sudo tee /etc/apt/sources.list.d/docker.list > /dev/null
sudo apt-get update
$ sudo apt-get install docker-ce docker-ce-cli containerd.io docker-compose-plugin
Hi @Andrea C
Welcome to the Community.
Atlassian (Docker) images were recently updated and now require Docker Engine version >= 20.10.9.
The issue is related to the update to the Adoptium OpenJDK and incompatibilities with older versions of the Docker Engine.
Refer to each product's Docker Hub page:
Upgrade the Docker Engine to version 20.10.9 or a more recent one.
Refer to Docker Engine release notes for more information about Docker versions.
Go to https://hub.docker.com/r/atlassian/jira-software and you will see that now docker engine >= 20.10.9 is required. As mentioned above, that will resolve the issue.
I am still getting same problem after upgrading docker to 20.10.17.
trying to upgrade confluence from 7.14.3 to 7.18.2
# docker -v
Docker version 20.10.17, build 100c701
confluence | Cannot find /opt/atlassian/confluence/bin/setclasspath.sh
confluence | This file is needed to run this program
Have you restart docker service after upgrade?
I can start confluence 7.18.2 (upgraded from 7.18.0) with docker 20.10.17, CentOS 8.4.2105.
Could you provide more information about you OS version, confluence image hash, etc?
Yes, I have restarted service and tried docker-compose up -d .
Redhat 7.9
Kernel :3.10.0-1160.66.1.el7.x86_64
Image Id: sha256:2e21be1a3328986cc7b73fada09427e2fc43ee87de8cd345bea3f562b7b60a91
Could you upgrade from 7.14.3 and try
Hi Andrea!
I have the same scenario than yours but I know that our docker engine is out of date. However, do you have best practices to ugprade Atlassian apps using compose? I've tried updating our JS version from 8.5.X to the latest LTS version just changing the jira tag but it's not working. I believe I had checked all the internet trying to find best practices using compose and I was unable to find anything that help me out.
You need to update your docker engine before updating any Atlassian app, there is no way around it.
Follow the commands from the answer of idan_payne.
I had already installed the GPG key and the repository the first time I have installed Docker so I just did
sudo apt-get update
and
then I checked the docker version to be sure everything went fine and then updated the tag in the JS docker-compose file and restarted the container (docker-compose up -d)
Having the same issue here :(
Read the story
