Cant create a software project from a software project.
PertechNum5Daniel February 26, 2025
I have an issue with the import data option when creating a new project.
1. Create project
2. Select:
3: Select where to import from:
If I chose software project I will get this:
If I chose business project I will get this:
The issue is I don't want to create a business project from a software project. I want to create a software project from a software project.
Note that the drop down in both cases only has one option (software project or business project).
Trudy Claspill
Hello @PertechNum5Daniel
This is a known issue that has come up in other Community posts.
https://community.atlassian.com/t5/Jira-questions/Cannot-import-Software-Project-as-Software-Project-forced-to-be/qaq-p/2830191
https://community.atlassian.com/t5/Jira-questions/Import-Jira-software-project-into-a-software-project-not/qaq-p/2786582
I have not found any links in those posts to a bug or change request, nor can I find such a change request in searching the Atlassian public backlog.
https://jira.atlassian.com/secure/Dashboard.jspa
I recommend that you open a support request directly with Atlassian to ask about this, and if they report back to you a link to a change request please share that here.
