Cascading Custom Field Multi-select
Antoine
August 26, 2016
Hello everyone, I am a bit annoyed because of a small problem ..
I created a custom field, type cascading and I would incorporate a multi-select  on the second list, someone would have a solution to this problem?
Hoping to have been clear, and understandable.
4 votes
Nic Brough -Adaptavist-
August 26, 2016
You'll need code to do that - I'm not aware of any add-ons that provide such a field directly.  This is not something you can bodge with javascript on a cascading select as the field physically stores a single option, you will need a new field type for it.
If you've got behaviours (from Script Runner add-on) or another add-on that can link fields, you could have a single-select and a multiselect linked together to behave a lot like a cascading multi-select.
Antoine
August 26, 2016
Thank you for your detailed answer, I'll see what I can do, if it ends I will inform on this post.
August 26, 2016
By the way, Peter's answer has just made me realise that I have made an assumption that you wanted a particular result.
He's suggested the "multi level cascading select" - this is a good option, but still only has one value stored.  I've assumed you wanted to select many options in the second list.
In case that's not clear, let's say you look at a normal cascading select:
First column optionSecond column option
State
<none>
Ohio
Washington
Texas
County<none>
Berkshire
Northamptonshire
Lancashire
In this, you can only end up storing one value - a single one of the eight options in the second column
What I think you asked for is
col 1col 2
State
<none>
Ohio
Washington
Texas
County<none>
Berkshire
Northamptonshire
Lancashire
Storing several options together - County:Berkshire, County:Lancashire aand State:Ohio all in the same field.
What the Multi-level thing does is give you more layers.  But it still stores a single answer.
col 1col 2col 3col 4
Antoine
August 26, 2016
What I am looking it would for example have in the end the values of "Washington" and "Ohio".
The first list will be a single select list, and the second list will be a multi-select list.
Tayyab Bashir
September 6, 2016
Hi  Nic and Antoine,
I'm looking for a similar thing.
Multi-level cascading on the second list (Given a single option in list 1, multiple options stored in list 2). Just like the County, Country example that Nic provided.
Did you find a way to do it?
Antoine
September 6, 2016
I have unfortunately found nothing
Kalpana Ramesh September 19, 2016
Hi. Are there any alternative ways to achieve this?
September 19, 2016
There are two ways I know of to do it, both given above.
Hi Nic, you suggest linking a select and a multi select list.
How can that be done?
September 19, 2016
I'd go get one of my colleagues who knows how to configure Behaviours in the Script Runner
Yes, Thank you!
siva
@Nic Brough -Adaptavist-
as you have mentioned , i have a request to attended,
tried customfields from script runner but still missing some thing, could you check and suggest a way i can make it possible.
Custom field  A  Drop down list  user select custom field
   (A,B,C,D)  (can select multiple users)
Any possibility i can acheive this .
Thank you
jordan January 15, 2020
Any code examples would be incredibly helpful as I'm stuck on this at the moment, too.
Like Yatish Madhav likes this
January 16, 2020
jordan January 16, 2020
Thanks!  I'll check it out.
I'm new to Jira, so thank you for bearing with me.  I created 2 Custom Select List Fields -- one Select List (single choice), one Select List (multiple choices) -- and put them on the correct screens, etc.  I created a new Behavior with them and mapped them to the project.  I put the code from here (https://library.adaptavist.com/entity/set-available-options-to-a-multi-select-list) into the Single Select List script field and changed the appropriate names in the script with the cases in the switch statement being the Single Select field options I want and the setOptions being the Multi Select field options I want.  I've tried this with seed data in the original fields and without (thinking the script might populate the field options).  Nothing seems to be working.  Is there anything obvious I'm doing wrong from the above information?  Thanks again.
jordan January 21, 2020
I think I figured it out.
shubham.thukral
March 2, 2020
Jordon,
Can you please share what was the issue ?
jordan March 2, 2020
I removed the "package scripts.setAvailableSelectListOptions" from line 1 of the code and it works.
shubham.thukral
March 2, 2020
Thank you so much for your quick response. Much appreciated.
Tanu
@jordan , i wanted to know did you create two fields where :-
1) Single Select Type and another 2) Multi select type.
So how will they act like cascading fields?
I have a need where i want multiselection of options in cascading type of field, is that relatable to the code you used?
please guide me here i am stuck.
Like Maksim.Feshchanka likes this
Peter Geshev
August 26, 2016
Hi Antoine,
There is no native way to do that, as the native cascading selects are not multiple.
Peter
Antoine
August 26, 2016
Thanks for your answer
Michel_Lavoie November 29, 2019
I wish I could try it but I am on Jira Cloud :(
November 29, 2019
Yes, I'm afraid Cloud can't/won't support it.
rjiao
May 21, 2020
@Nic Brough -Adaptavist- hello Nic, confirmed that MLCS add on doesn't work on Jira cloud.
Do you know how do we achieve this? could the ScriptRunner for Jira cloud help this? or coding with Jira cloud api?
thanks!
May 21, 2020
Cloud cannot support this, it's not changed since my last comment.
Like robin Jiao likes this
