Sign up Log in
Case insensitive search on Enhanced Search
Kev March 3, 2025
Hey all,
I'm completely at a loss as to why my query is not returning any rows while trying to do a case insensitive search on the labels field.
The query that currently returns 514 rows is:
issueFunction in issueFieldMatch("type IN (Defect) AND status IN ("In Progress", "In Refinement", New, "To Do", Done)", labels, "^iBCore") ORDER BY Created ASC
But I know the query above is missing records which are labelled IBCORE instead of iBCore. So the plan is to do an insensitive search using:
issueFunction in issueFieldMatch("type IN (Defect) AND status IN ("In Progress", "In Refinement", New, "To Do", Done)", labels, "($i)iBCore") ORDER BY Created ASC
However this fails to parse.
Can anyone suggest a way to get this to work please? I'd really appreciate it.
Cheers
Kev
Tuncay Senturk
March 3, 2025
The issueFieldMatch() function uses regular expressions, but afaik, it does not support case-insensitive matching directly within the regex pattern.
I am not sure but could you try this? adding ?i at the beginning of the regexp make the search case insensitive.    "(?i)^iBCore"
ENTERPRISE
