I would like to change the Fix Versions field name to Sprint Version number as we are using that field for Sprint numbers. So, I was thinking that I should change the field name.
So, two questions -
You could create a custom field of the type Single Version Picker.
That will have the same functionality and will have the name Sprint Version Number.
More information can be found here : https://confluence.atlassian.com/display/JIRA/Adding+a+Custom+Field
Best Regards
Peter
Not if you're using OnDemand.
Standalone users have this option: https://developer.atlassian.com/display/JIRADEV/Customizing+Text
