×Hello,
I'm trying to set the Original Estimate automatically upon the creation of a new issue.
To do this I have added a Workflow Post Function to the Create transition by setting the Original Estimate to 15m from the Update Issue Field settings.
I then publish the workflow.
However, when I create a new issue the Original Estimate remains blank.
I have tried a other variations of the Original Estimate (0.25h) and still nothing changes.
Is there step/setting that I am missing?
Hi @Rod McWilliams,
Even I noticed the same issue after adding the original estimate related post-function and when it's placed 2nd in the post-functions order.
So, can you please move this post-function to the top as shown in the screenshot and try to create the issue.
This worked for me and I'm able to see the original estimate value once the issue gets created.
Hope this helps!!
Priyanka
Thanks @[deleted],
Fixed it for me too.
Thank you so much.
cheers
Rod
