Change detail view - remove or add options
Matthew Dartez May 9, 2016
So in the detail overview:
image2016-5-9 9:50:16.png
How do you remove or add items here? For example, we're trying to get rid of "Affects Versions" for this project and the Epic/Theme (since epic already exists at the bottom).
Nic Brough -Adaptavist-
May 9, 2016
If you hide the versions in the field configuration, that will remove it from the details panel too.
I don't think you can remove the Epic/Theme without disabling the Epic functionality though
