Currently when Jira and Confluence Cloud send emails via notifications or automation, in the header of the email there is an entry used for security called "mailfrom". Currently this entry is set to smtp.mailfrom=jira@mail-us.atlassian.net as can be seen in the authentication results section of the email header below:
Authentication-Results-Original: esa.hc463-99.ca.iphmx.com; spf=Pass
smtp.mailfrom=jira@mail-us.atlassian.net; dkim=pass (signature verified)
header.i=@mail-us.atlassian.net; dmarc=pass (p=reject dis=none)
d=atlassian.net
This is true even though the "From:" address is set to something like jira@tenantname.atlassian.net. NOTE that the "From:" address is independent of the "smtp.mailfrom" address.
In Exchange, if it were coming from a trusted mailfrom address there will be a banner like this on the email:
The way things are now, the banner would indicate that the source is not trusted.
This request is to have the SMTP mailfrom domain set to the tenant domain itself i.e. smtp.mailfrom=jira@tenantname.atlasssian.net OR smtp.mailfrom=tenantname@mail-us.atlasssian.net so that from a security perspective these messages can be trusted and not spoofed from other tenants.
Hello @Jim D
This is a community of users of the Jira product, not specifically a feedback channel or support channel for contacting Atlassian.
I recommend that have you Jira Administrators open a support case directly with Atlassian to discuss this issue. They can do that at https://support.atlassian.com/contact/#/
Thanks - my administrator did contact support, but didn't really understand the specifics of the problem and were given incorrect answers that they 100% believed. When trying to open a ticket myself, the Atlassian website directed me here and mentioned that Atlassian staff did join these discussions and may be able to help.
I understand that a solution would require a Jira (and Confluence) software back end change.
With Atlassian closing the ticket based on misunderstanding the problem, I'm hoping I can get someone from Atlassian's attention through this community post.
