×Hi, I'm designing a Kanban board with Epics on it. I plan to have a field called 'Funding approved' which will be a checkbox. I want to change the Epic card colour on the Kanban based on this checkbox status.
If unchecked then Epic colour = red
If checked then Epic colour = green.
Is this possible? would be very cool to be able to this or something similar?
Is there any way of controlling the epic colour from any epic data?
Hi Stu
If you are administrator of the Kanban board, then go to Board / Configuration, there is a tab called Card colours, which allows you to define the colour of card based on a query. In your case it might be "issuetype = epic and nameofyourcheckbox = yes"
