×Is there any way to change the fields that are displayed in GreenHopper, on the panel on the right?
There are fields there like Version and Fix which we don't use for our projects but I can't seem to find how to remove them. We have custom fields that we would rather display there....
Here's a screenshot of the panel I am referring to:
Hi Tudor,
I'm afraid this is not possible to achieve at the moment. This is currently a feature request that currently being tracked here:
As a Rapid Board user I would like to configure the detail veiw for an issue
I will suggest you to vote on it and watch the issue to get notification for any update related to the issue.
Hope this helps, Vicky.
Thanks, I will vote on it now :). Hopefully it comes soon.
With the latest version, you can add Text or numeric fields although can't customize the other aspects yet. I learned it the hard way, by getting few negative votes from Atlassian developers!.
Have an upvote, to offset some of the negatives you got. Clearly you're in dire need of karma ;-)
hehehe. It is good to get some negative votes though. You won't forget such stuff easily. lol.
Ups, this is a duplicated post. Please refer to the orignal post for more detail explanation.
Thanks, Vicky.
