I haven't found a way of doing that works for me, this method return an error : 500
url ... /jira/rest/api/2/issue/JC-11/transitions?expand=transitions.fields
"update"
"comment"
"add"
"body"
"Comment added when resolving issue"
"transition"
"id"
"5"
Hello Ofer,
Could you please add the JSON to a file (i.e.: parameters.json)
'{ "update": { "comment": [{"add": {"body": "Bug has been fixed."}}] } , "fields": {"assignee": {"name": "osh"}, "resolution" : {"name": "Fixed"} },"transition": {"id": "21"} }'
Then call the cURL as per following:
curl -D- -u [USERNAME] -p -H "Content-Type: application/json" -X POST --data "@parameters.json" https://xxxx.atlassian.net/rest/api/2/issue/SUMA-6/transitions
Could you attempt on running the cURL provided in this thread in different boxes, please?
If you find this answer useful, I would kindly ask you to accept it so the same will be visible to others who might be facing the same issue you have inquired.
Thank you for your understanding.
Rafael P. Sperafico
Atlassian Support
Hi Rafael,
I finally got it to work it seem like the fields asignee and resolution wasn't defined, so i used only transition and it works!
{ "transition": {"id": "21"} }
Thanks for your help.
Ofer.
I wasn't ware cUrl returns anything else but an Error.
I'm using my own c# program to call rest api, I've followed your instruction and set transition id according to my project.
Here is my cUrl command:
curl -D- -u api-admin -p -H "Content-Type: application/json" -X POST -d
'{ "update": { "comment": [{"add": {"body": "Bug has been fixed."}}] } , "fields": {"assignee": {"name": "osh"}, "resolution" : {"name": "Fixed"} },"transition": {"id": "21"} }' https://xxxx.atlassian.net]/rest/api/2/issue/SUMA-6/transitions
cUrl response:
Enter host password for user 'api-admin':
curl: (3) [globbing] unmatched brace in column 1
curl: (3) [globbing] bad range specification in column 2
curl: (3) [globbing] unmatched close brace/bracket in column 20
curl: (3) [globbing] unmatched close brace/bracket in column 4
curl: (3) [globbing] unmatched close brace/bracket in column 6
curl: (3) [globbing] unmatched close brace/bracket in column 3
curl: (3) [globbing] unmatched close brace/bracket in column 33
It make no sens, all braces are in place.
Ofer.
Hello Ofer,
Thank you for your question.
You can verify the transition ids under "JIRA administration >> Issues >> Workflows" by clicking on "Operations >> View" to the selected workflow. In my example below, I have selected: "The default JIRA workflow."
By running the cURL commands that have been mentioned in this thread, the response will tell you what is wrong and what needs to be done. It would be easier if you could provide the command you are running and the response given so we could verify the issue you are facing and provide you with a better response.
Rafael P. Sperafico
Atlassian Support
Hi Rafael and Jaime,
Thank you for your response, I’m afraid it’s still not working for me … Here is my post data:
"update":
{"comment": [{"add": {"body": "Bug has been fixed."}}]},
"fields": {
"resolution": {"name": "Fixed"},
"transition": {"id": "500"} }
Posted to this url: https://xxxxx.atlassian.net/rest/api/2/issue/MAIT-150/transitions
I also wonder about transitions state codes:
What is the code for:
Ready -> InProgress transition
InProgress -> Done transition
Ofer
Hello Ofer,
As @Jaime Silveira has mentioned there is no need to expand in the REST API call. Instead, you could be running the following command as mentioned earlier:
# [USERNAME], i.e.: admin # [ASSIGNEE], i.e.: someone # [JIRA-BASE-URL], i.e.: http://my.jira.domain # [ISSUE-KEY], i.e.: ABC-1 curl -D- -u [USERNAME] -p -H "Content-Type: application/json" -X POST -d '{"update": {"comment": [{"add": {"body": "Bug has been fixed."}}]},"fields": {"assignee": {"name": "[ASSIGNEE]"},"resolution": {"name": "Fixed"}},"transition": {"id": "500"}}' [JIRA-BASE-URL]/rest/api/2/issue/[ISSUE-KEY]/transitions # in the command above, you will be prompted to type in user's password # alternatively, you could run # [USERNAME], i.e.: admin # [PASSWORD], i.e.: mypassword curl -D- -u [USERNAME]:[PASSWORD]
Rafael P. Sperafico
Atlassian Support
Hi, Ofer.
Since you're using Cloud, when you replaced the 'localhost:8080', did you remove the '/jira'? This is not included in Cloud instances.
It would be something like:
instance.atlassian.net/rest/api/2/issue/JC-11/transitions
Also, this is a POST, so I don't think you should use the expand.
If these changes don't work, could you send us the full command you're using?
I hope it was helpful.
Jaime Kirch da Silveira
Atlassian Cloud Support
Read the story
