Good Morning
I've been asked to change auto-assignees in a few workflows when a certain transition is triggered / status is started
This isn't a default in the project setting and i've also checked post functions / triggers / automation and can't see these set up anywhere
Maybe there is something i've missed?
Sherry
This was biting me as well for a while. I managed to find a different 'new' place introduced by Atlassian which was messing with auto assignee.
Project Settings -> Components.
Within this, if issues are mapped to one of the components and if the component has a default assignee, this will override project's default assignee.
By default, annoyingly, it was mentioned as 'Project lead' rather than 'Project default'.
Hello @Sherry Nightingale
In the post functions have you checked "Update Issue Field"? By default Assignee is selected.
You have three options here, depending on your requirements you can adjust them:
