I have my settings set for English US but when I use Atlassian Intelligence it uses the English UK version. Is there a way to fix this?
Example:
I prefer behavior but behaviour is generated.
I understand that when using Atlassian Intelligence, some parts appear to be using UK English when you would prefer US English. Could you check your personal settings in https://id.atlassian.com/manage-profile/account-preferences ?
Your Atlassian Cloud products should honor the selected language selected there. However I came across a known issue in regards to smart values in automation might be set to English when the user selected language is different.
If your account preference is set to English (US) and you can still see (UK) examples, I'd be interested to try to learn more about exactly where those appear so that we can better identify and track adjustments to them.
Andy
My settings are for US and the AI for improve description misspells behavior for us. This is barely an issue and one that one of my co-workers noticed. We just change the spelling and for me it only appears to happen with the improve description.
Thanks for clarifying. I believe that this limitation is something we are tracking over in AI-5. It would appear that some features within Atlassian Intelligence are still defaulting to a UK version of English despite the end user's desired language settings.
Basically AI should use language of your profile settings. Is there any difference when you ask and point exactly to AI to give you result in English US or mention to it that you prefer to use your default language? Does it recognize it correctly then?
Didn't find any supporting Documents for this but as per this thread if you change your personal setting it updates the response language https://community.atlassian.com/forums/Confluence-questions/Re-How-to-change-the-response-language-of-Atlassian-Inte/qaq-p/2596803/comment-id/290918#M290918
I would suggest raising a ticket with the support team to get more clarity on this though.
I have tagged them in this thread to get their inputs on this.
