Dear all,
How change o field from Select List (single choice) to Select List (multiple choices). If is it possible?
Hi @Paulina Mijal ,
As far as I know, Custom field types cannot just be migrated to another type.
You'll have to create a new custom field with the correct type and (if needed) migrate the data over.
Hi Paulina,
Dirk is correct about field migration. It may be possible to use the API or a plugin (like Scriptrunner) to copy custom field values between the old and new fields. Cheers!
@Dirk Ronsmans @Joshua Sneed Contegix Thank You. @Joshua Sneed Contegix what do you mean by API - Could you elaborate on that?
Hi Paulina,
The Jira Rest API. https://docs.atlassian.com/software/jira/docs/api/REST/8.13.13/ cheers!
Hi @Joshua Sneed Contegix @Dirk Ronsmans
could you be so kind and check my problem Configuration of a screen preview. (atlassian.com)?
@Joshua Sneed Contegix finally, I have a scriptrunner plugin :) Could you tell me how could I change this file type?
