I have a custom workflow and when it is created for a certain project it should be assigned to a specific project.
I tried to create a post function on the create transition of updating the assignee field with the user but for some reason when create it just leaves the assignee as unassigned.
I have used this post function on all of the other transitions, is there a way to get this to work?
