Changing next-gen issue type on a ticket
Jack Lord August 19, 2019
Hi there,
I've noticed with next-gen projects it seems we now have to "move" a task to change the issue type; previously I believe this required max 2 clicks (click on current issue type then click on the new one from the dropdown) however, with moving, it's a really long process and not very simple. Am I missing something or is there a way to change issue types with 2 clicks?
elenushhh
August 20, 2019
Hello @Jack Lord
You can still change the issue type from dropdown list. can you provide a screenshot ? I verify this on my next-gen project and is working.
If I click on the task it opens is the right and you can change it from there.
Jack Lord August 20, 2019
Hi @elenushhh
Yes, I can reach the dropdown, however when clicking on any of the other options it takes me to the "move task" operation, which is what I don't want to have to do.
Thanks for helping!
Nic Brough -Adaptavist-
August 20, 2019
You have to use "move" if the issue types do not share their configuration - only the move function has all the checks and questions about converting between configurations.
@Nic Brough -Adaptavist- How do I check their configuration and make it the same? I'm purely trying to use these as labels to differentiate tasks in our backlog, but sometimes we need to change them. It shouldn't change anything except the icon (regarding workflows/configs).
Luis Garza August 23, 2019
@Nic Brough -Adaptavist- - I got the same Question as @Jack Lord  Any guidance on how to verify the configuration difference?
The only place I got is the https://subdomain.atlassian.net/projects/PROJECT/settings/issuetypes/ISSUE_ID
I have compared all my issue types and they match... I must be looking at the wrong place.
On the classic Jira workflows I don't see the next gen project workflows/ issue types.
September 11, 2019
It's in the project settings, you need to check that the issue types use the same workflow and configuration scheme, and then also that they have the same custom field contexts from admin -> custom fields.
Register today
