Changing the Issue View Screen
jon miller June 14, 2018
Hi
Couple questions related to viewing issues.
-How can i make the list view the default view method when looking at issues?
-I see how i can change the fields that are viewable on the issues page and how i can sort them but how can i set or save a list of fields and the layout so its default each time? I am rarely ever using the default Jira fields but they always come up even after i change them.
-Do i need to use the summary field or is there a way to change the name? Is that the only field that one can click on to view the details of an issue?
jon
Prakhar Srivastav {Appfire}
June 14, 2018
Hi @jon miller
As Admin you can set these defaults for your users.  In turn this would be applied to all your projects.  Users could then set their own filters as they would like.  Here's a portion of the article, the link is below.
"My Defaults, Filter, and System
If the currently selected button is My Defaults, this indicates that the columns you are seeing are from your user account preferences. Filter is an available option whenever the issue search results come from a saved filter. If you are a JIRA Admin, you will also see the System tab, where you can change the columns for all users who have not set their own defaults"
Please refer to this document.
https://confluence.atlassian.com/adminjiraserver072/configuring-the-default-issue-navigator-829827009.html
Register now
