I am trying to make an automation that edits the summary to show two text entries that are added via a smart form. I am able to get 1 working via the copy function but cannot seem to get the code to show these values at all.
Here is the XLM from the backend of a sample that I want to add:
What am I missing here?
The only difference I see between the two is 'textfield' at the end of the key for the one I am trying to add whereas 10127 has select.
Any help would be appreciated.
Hi @GREY Stuart -- Welcome to the Atlassian Community!
If you are trying to copy/concat two custom fields into the Summary, have you tried just using smart values and the concat() function?
Hi Bill,
Thanks for taking the time to get back to me.
I actually found a simple answer...it was {{customfield_10377}} - {{customfield_10324}}. I was just over complicating it...Good result to finally get it to work.
Stuart
Hey @GREY Stuart ,
Glad to know you were able to work out a solution.
Would be great if you can mark the thread as accepted so it gets identified as a valid answer.
Hi Jehan,
I am actually not sure how to mark the thread as accepted?
Register today
