Checking parent issue is in a specific status before sub task transitions from one status to another
Keylane ICT May 27, 2020 edited
I've tried using the ScriptRunner plug in with a groovy script:
issue.parentObject.status.name == "REALISATION"
I used a conditional custom script to be placed at the transition between the statuses but it doesn't seem to work. I would like to use the scriptrunner plugin as we do not have the capacity for the jira workflow extension.
Thanks all.
František Špaček _MoroSystems_
May 27, 2020
is really your status in capitals? Jira make them appear in capitals in UI, but you need to check proper status name in administration (Issues -> Statuses).
Also, better way to write the script like this:
issue.parentObject?.status?.name == "Realisation"
 Where ? makes it check if the object exists. In your solution if parentObject or status return null, script crashes. With ? it won't crash.
Have a nice day.
Yes the status is really in capitals. Thank you for that insight, it did worked out in the end. :)
Margaret He
October 21, 2021
This script worked for me! Thank you!
SERVER
VERSION
7.13.12
