Checklist field does not appear in Issue Detail View on a Agile Board
amandavarella
Hi, I m having this problem.
In the general fields, when I search for a specific field that is a checklist, the combo doesn t bring the field I would like to have.
Any Ideas?
Yves Riel _Okapya_
Hi Amanda,
In order to display the Checklist in the Agile Board detail view, you need to create another customfield from the "Checklist Read-Only Proxy" customfield type. This new type is installed with the Checklist Add-on. Configure the proxy customfield to point to your Checklist and than the Proxy customfield will be displayed in the combo box and you will be able to display the Checklist in the detail view.
It is as described in the link you refer too. If you still have some problem with this, let me know.
Yves
amandavarella
There is a known problem reported here:
http://okapya.com/checklist/displaying-in-Jira-Agile
Yves Riel _Okapya_
Just to let you know that the next release of Checklist (late March or early April 2018) will have a view to edit the checklist directly from the details view. Go tired to wait for a fix to come :-)
Yves Riel _Okapya_
If someone is interested into beta testing it, please contact us :-)
Alexey_Rjeutski__Polontech_
August 14, 2014
amandavarella
Yes. There is a known problem reported here:
Here, he also describes the workaround for dealing with this problem
Let's build A Rovo Agent 🤖
Save your spot
