Checklist jira addons
Nicolas Andika
Dear all,
Is there any recommendation of jira checklist that is free and no maximum usage?
Thankyou
4 votes
olena_tsarova
Hi @Nicolas Andika
If you're using Jira Cloud, I'd suggest  Smart Checklist for Jirahttps://marketplace.atlassian.com/apps/1215277/smart-checklist-for-jira-free?tab=overview&hosting=cloud
It does have a 20 item checklist limit per issue, but there's no limit on how many checklists you can create per instance.
3 votes
Angela Thomas_Seibert Group
October 22, 2024 edited
@Nicolas Andika I'd like to direct your attention to Didit - Checklists for Jira.
While it's only free for up to 10 users, the app does not have any limits on the number of checklists you can create. It also seamlessly syncs with Confluence. We'd be happy to offer you a personalised demo. Talk to the product team
Manoj Gangwar
Hi @Nicolas Andika
There are no free Jira checklists with no maximum usage, but there are some free options with limits:
  • Checklist for Jira | Free
    Allows up to 20 checklist items per issue, and 10,000 checklist items per instance. Once the 10,000 item limit is reached, you can't add more items, but you can still edit, check, uncheck, replace, or delete existing items. You can upgrade to the Pro or Enterprise version to remove the limit.
  • Smart Checklist for Jira
    The free version is limited to 20 items per checklist and 5 templates. It's only available on Jira Cloud.
  • Checklist for Jira Cloud (Free)
    Offers all the features of the Enterprise version, but with a limit of 1,500 checklist items per month.
Nurlan Mirzayev _Tick_
Dear @Nicolas Andika ,
I'd love to invite you to try Tick | Checklist for Jira our free Jira checklist app with no limits on usage. It's currently a rising star in the marketplace, offering a wide array of features while being incredibly user-friendly.
Feel free to give it a try, and let us know if you have any questions!
Ollie Guan
October 21, 2024 edited
Hi @Nicolas Andika ,
This plugin is very easy to use and stable. We have installed it in our Jira enterprise plan and provide services for 1000 users.
Marc - Devoteam
October 21, 2024
Hi @Nicolas Andika
My recommendation is Checklist for Jira | Free by Hero Coders, or Smart Checklist for Jira (Free) by Titanworks.
All free options have some kind of limit, of you want limitless, your will need to go for a paid solution.
Rilwan Ahmed
Check this https://marketplace.atlassian.com/apps/1220209/checklist-for-jira-free?tab=overview&hosting=cloud
You can always make search in https://marketplace.atlassian.com/ and find required apps.
Example: https://marketplace.atlassian.com/search?query=checklist&hosting=cloud&price=paid
Please note: Apps which are free today can become paid in future.
