×Hi all,
I am trying to use listeners to clear the field value for some fields as soon as the issue gets updated.
The fields which I want to have cleared are in another tab. Nevertheless, I have listet them as below.
// get custom fields
def customFields = get("/rest/api/2/field")
.asObject(List)
.body
.findAll { (it as Map).custom } as List<Map>
def toUpdate1CfId = customFields.find { it.name == 'Compliance Risk' }10257
def toUpdate2CfId = customFields.find { it.name == 'GDPR Risk' }10258
def toUpdate3CfId = customFields.find { it.name == 'Business Risk' }10259
def toUpdate4CfId = customFields.find { it.name == 'technical Risk' }10432
def toUpdate5CfId = customFields.find { it.name == 'Compliance Prio' }10260
def toUpdate6CfId = customFields.find { it.name == 'GDPR Prio' }10261
def toUpdate7CfId = customFields.find { it.name == 'Business Value' }10262
def tomorrowStr = (new Date() + 1).format("yyyy-MM-dd'T'HH:mm:ssZ", TimeZone.getTimeZone("UTC")) // date format in iso8601
def resp = put("/rest/api/2/issue/${issue.key}")
.header('Content-Type', 'application/json')
.body([
fields: [
(toUpdate1CfId): 'NULL',
(toUpdate2CfId): 'NULL',
(toUpdate3CfId): 'NUKK',
(toUpdate4CfId): 'NULL',
(toUpdate5CfId): 'NULL',
(toUpdate6CfId): 'NULL',
(toUpdate7CfId): 'NULL'
.asString()
assert resp.status == 204
Also, defined the trigger as seen in the screenshot.
Do you have any experiences on this? Any advice how to make this work?
Thanks a lot!
Best,
Xheneta from Munich
Hi @Xheneta G. Hyseni I am not sure how script runner listner works in JIRA cloud. But an alternate solution is that you can use Project Automation to clear field value when issue is updating.
Similar post :- https://community.atlassian.com/t5/Jira-Service-Management/How-to-use-automation-to-clear-date-value-on-change-of-status/qaq-p/1525817
V.Y
Hi @Vikrant Yadav ,
That does not really work in my case since I got a a few fields to update unfortunately. I already tried it with automations first.
Thanks anyway!
