Clone, duplicate or link?
joesoes January 26, 2017
Example: if I cone/copy an issue to another board, and then a team member moves the issue to Done, then I want the original issue in my board to be moved to Done in my board as well. Is that even possible?
Kian Stack Mumo Systems
Hello Johan,
This is not possible out of the box with JIRA. There are several plugins that can help you accomplish this through the use of a post function.
Check out this plugin which I believe is free. https://marketplace.atlassian.com/plugins/com.innovalog.jmwe.jira-misc-workflow-extensions/cloud/overview
Kian
Prabhu Marappan
February 7, 2019
HI @Kian Stack Mumo Systems,
Here in 2019, Is this possible out the box?
No, this is not possible with the base functionality.
