Dear community,
I have a project B in which epics are created that are cloned from another project A. In parallel, in my project B I have an automation that creates tasks when a new epic is created, but it is not executed when the epic is cloned from another project. What could be the problem? How should I set up my automation so that it recognizes a new issue, even if it is cloned?
Thanks a lot!!
Hi Francisco,
If the Epic is cloned/created by an automation rule, then it is probably that the second rule does not have the box checked on the Rule details page to allow the rule to be executed by another rule.
Check that box and update the rule and give it another try.
Thank you very much!
I checked the box in the rule that should create the tasks and it worked perfectly!
Regards!
Great! Glad that worked.
Hello @Francisco Navarro
In order to diagnose why your rule might not be working we need som additional information. Please provide the following:
