Close a linked issue when an issue is closed using automation?
Waseem Haddad
Hello community,
I have 2 tickets linked in one project and I want to automatically close the second ticket when the first one is closed.
Can anyone help me?
Thanks in advance
4 votes
Walter Buggenhout
Hi @Waseem Haddad,
As long as there is indeed a link between the issues AND the status of the linked (still open) issue has an available transition into the done/closed status you are trying to move it into, that should be fairly straightforward.
The rule should look somewhat like this:
You can add additional conditions where needed and I would recommend to also set the value of the resolution field to done in the last step as well.
Hope this helps!
Waseem Haddad
Hello @Walter Buggenhout ,
I have tried it and it works, Thank you so much.
I wish you a nice day ahead
Waseem Haddad
One more question.
If I want to automatically comment on all linked tickets with the same comment, as long as I post my comment on the master ticket, how can I do that?
Walter Buggenhout
@Waseem Haddad ,
As this is a different question, it's better to post this as a new question in the future. If I don't reply anymore or give you a totally wrong answer to this one, other users in the platform here might get confused as you've accepted my answer (thx for that, btw).
For now: you can use a very similar structure, but a different trigger and another action:
Mind the smart value I used to refer to the last comment added to the issue that triggered the rule.
Waseem Haddad
Thank you so much for your help, I will be more careful with how I form a question.
Have a nice day ahead
Waseem
Waseem Haddad
One more question.
Learn more
