How do I create a dashboard or generate that shows number of tickets closed/resolved by each support person?
Chris
Hello @Chris Rhodes
Do you consider the Assignee to be the person that Closed/Resolved the issue, or do you want to count based on the person who actually executed the transtion?
You could create a filter to retrieve all the issues in the Closed/Resolve status of interest.
Then in a Jira Dashboard you could add a Two Dimensional Filter Statistics gadget. Select Status for the X Axis and Assignee for the Y Axis.
You would end up with output something like this, showing only the Statuses that you had included in your filter:
Use a Filter Results gadget on a dashboard. There are several posts explaining how to do this, however, it's pretty straightforward.
