Jira Cloud: Not having a capability to apply a single template including its field layout/fields order etc and making changes from project to project is a big challenge. This sounds like serious issue for someone who wants to apply a Uniform UI template with Fields in both 'Create and View' screens.
Is there a fix coming for this?
Hi Yaadi,
I hope you are doing great.
Have you tried using screen tabs? It worked for me when I used a different screen tab from the default one. (the default tab is important, so it should not be deleted, you can just leave it without fields instead)
What I did was create an additional tab (or tabs) and use the field order I wanted in the other tabs.
Please let me know if this works for you,
Best Regards,
Adriana
