Cloudlare SSL & NGINX
Vlad Suciu
June 19, 2018
I have installed Jira then added Nginx as a reverse proxy so that the site is available at the default HTTP 80 port.
The Nginx configuration is fairly simple:
server {
    listen 80;
    server_name jira.domain.com;
    location / {
        proxy_set_header X-Forwarded-Host $host;
        proxy_set_header X-Forwarded-Server $host;
        proxy_set_header X-Forwarded-For $proxy_add_x_forwarded_for;
        proxy_pass http://127.0.0.1:8080;
        client_max_body_size 10M;
 and the Connector looks like this:
<Connector port="8080" maxThreads="150" minSpareThreads="25" connectionTimeout="20000" enableLookups="false"
maxHttpHeaderSize="8192" protocol="HTTP/1.1" useBodyEncodingForURI="true" redirectPort="8443"
acceptCount="100" disableUploadTimeout="true" bindOnInit="false" scheme="http"
proxyName="jira.domain.com" proxyPort="80"/>
The site is then accessed through Cloudflare which has Flexible SSL Enabled. Meaning I should be able to access https://jira.domain.com.
It seems to be working fine, except for the fact that I get the following error message:
The Tomcat server.xml has an incorrect configuration:
scheme should be 'https'
proxyName should be 'jira.domain.com'
proxyPort should be '443'
Flexible SSL means the users will be able to access the site over HTTPS, but connections to the origin server will be made over HTTP. So why is Jira complaining about HTTPS? The secure connection is only between the user and Cloudflare. Nginx is receiving an HTTP Request. I guess there must be something that I'm missing.
Vlad Suciu
June 19, 2018
For anyone looking for the answer,  I managed to get it working by updating the connector:
acceptCount="100" disableUploadTimeout="true" bindOnInit="false" secure="false" scheme="https"
proxyName="jira.domain.com" proxyPort="443 />
The important part is secure="false" while at the same time using scheme="https" and proxyPort="443". The rest of the settings remain unchanged. So far it seems to be behaving as expected.
Thành Lâm
December 4, 2021
this is a magic
Like Lin Han Pin likes this
