Good Morning
I have created a filter to provide me with all our issues that have a target end set.
When I run that filter I do not see the "Target end Date" field in the results. When I select ".Column" to try to add it it will not allow me to do so.
How can I change this.
reagrds
Perry Cornforth
Can I confirm you have Jira Premium? Target End is usually a field which is part of Advanced Roadmaps.
Or, is this a custom field you have added?
I tested this on our instance (which is Jira Premium) and Target Start / Target End are both available via the Columns menu.
Ste
Good Morning
We are using the Cloud version
It is not a custom field We are using
Thank you / Merci
Perry Cornforth
Could you provide a screenshot perhaps of where the Target End field is on one of your issues?
Target End is usually a field reserved for Jira Premium, so if you have Standard I'd be keen to see what you're referencing to :)
Ste
