I have an interesting scenario in which Im combining 2 custom fields using a decimal (not basic math equations +, -), The equation looks like this:
In theory it takes two fields and makes a number in a third so for example if customfield 17544 is 1 and customfield 17545 is 10, the result will be 1.10 but, the equation keeps dropping the last zero and reflecting 1.1 which is problematic. Any thoughts?
Hi @Travis Hill
I hypothesize you are putting the result in a number field, and so the last digit is truncated. Is that correct? If you put the values in a text field I would expect the digits to be preserved.
I believe it is a number field. Is a text field the only way to achieve this?
Yes, as I do not believe the built-in plain number fields have a display mask / format.
